Project /coil a sketch around a curved surface
cl3m.germain
cl3m.germain
Hi all,
I am trying to find a way to project a sketch on a curved surface, but not just projecting it : i want the sketch to wrap arounf the curved surface so that it is not distorted.
See on the screen shot : my idea is to have many little "teeth" on the edge of that body. Like a gear.
I'm trying since quite a while but i can't figure out how i can proceed...
Thanks for your help !
Clém
Pavel_Holecek
I attched similar model with a projected sketch. There is improtant to select Sketch plane and use 'Along Vector' option. Let me know if it helped.
Regards
Pavel Holecek
Autodesk QA team
cl3m.germain
Thank you for your reply. But i would like to know if it is possible to project the sketch not following a linear vector, but in a circular direction, to avoid the distortion of it in the middle. So, it is possible to not project it, but roll it around ? There is a function in Solidworks that allows to roll sketches around a cylinder. I was searching for a similar function.
PhilProcarioJr
@cl3m.germain
Currently there is only one way to do this in Fusion. This thread shows the work flow. It's not ideal but it works. @donsmac posted a video that shows how.
https://forums.autodesk.com/t5/design-validate-document/sketch-on-curved-surface-or-boolean-a-patter...
Phil Procario Jr.
Owner, Laser & CNC Creations
