Trouble with draft angle flipping on re-compute
Dear all,
There is a bug (?) that is really annoying: "sometimes", a draft just flips to the other side (as if it was reversed by clicking the reversed icon in the draft dialog box). This can happen "anytime". I screwed up some models with our injection mold supplier because the once correct draft angles were wrong and I didn't notice.
Now, finally, I have a model where I can reproduce this behavior.
I cannot share it publicly, so if anyone from Autodesk is here to help me, please let me know how to share it privatly with you.
Roland
innovatenate
Autodesk Support
Autodesk Support
I noticed @Phil.E has already submitted this issue to development via the below forum discussion.
http://forums.autodesk.com/t5/design-validate-document/draft-angle-flips/td-p/5627458
Is this the same issue?
Nathan Chandler
Principal Specialist
Yes, same issue, sorry. I noticed the older thread after I had already posted the issue.
I have sent a model which is able to reproduce the issue easily to Phil and he has filed a bug.
I hope this gets fixed soon. It's pretty scary because this behavior can 'destroy' and of your models without you really noticing it.
Greetings,
Roland
