Profiles Don't Update Properly When Geometry Changes
josephNWHGZ
josephNWHGZ
I have a design with multiple offset splines. When I change the Height parameter the geometry updates properly, but the selectable profiles do not. Can anyone explain why this is happening and if there is a way to fix it or a workaround?
bwalker145
Seems like a bug to me. I can get some weird behavior to show up when making adjustments in either direction from your nominal.
TrippyLighting
That looks like a fat, control spline related, sketch bug! @rohit.bapat can you direct this to the Sketch team?
@josephNWHGZ
I have attached a model with a workaround that uses offset surfaces.
I project the edges of these offset surfaces into a 2nd sketch. However, it might well be possible that this isn't needed.
rohit.bapat
Hello all,
I investigated the issue. According to my investigation the issue will be fixed in a recent future update. I will ask the team to further investigate and confirm my findings.
Thank you
Rohit Bapat
Rohit Bapat
Sr. Product Owner
