Remove Lines from mirror operation
ruediger.hahn
ruediger.hahn
how can I remove the lines that appear, get left behind when I use the mirror operation. The bodies are united (+).
But the line on top makes it impossible to run a extrusion (z) operation 😞
thanks in advance.
Marco.Takx
Hi @ruediger.hahn,
Can you please share your file?
Without seeing it, it is hard to help you with your problem.
Within Fusion 360, choose File > Export and save it on your desktop.
After that upload it to this topic so that one of us can take a look at it.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
ruediger.hahn
sure! thanks. 🙂
jeff_strater
Are you referring to the top faces of your model?
Those faces are not planar, which is why they are not merged.  They are created from fit point splines:
You mention extruding them.  Extrude also works only on planes, so you will not be able to extrude them if they are a spline surface.  If you want a plane, you should use a line in this sketch.
Jeff Strater
Engineering Director
ruediger.hahn
Thanks a lot. I thought the form is okay with the vertex centered.
gwright
Very helpful! I extruded to an object that turned out to be at a slight angle and it threw everything off. I redid the extrusion using distance instead and the problem is solved.
Thanks!
