Problems with coil tool not centring
GRANTRICKARD
Observer Observer
GRANTRICKARD
Observer
Observer
Hi all
Im very new to fusion 360, I'm trying to create som knurling on a part with the coil tool but for some reason when selecting the centre it always off centres itself, what am I doing wrong hear? Is there a way of editing the centre of the coil after the diameter has been set? Thanks.
TheCADWhisperer
@GRANTRICKARD
GRANTRICKARD
Observer
Observer
Im trying to add it to the sides of the body named lid. Thank you for your help!
TheCADWhisperer
@GRANTRICKARD
Why did you use Offset and 4 arcs in Sketch2 rather than one circle?
TheCADWhisperer
@GRANTRICKARD
Would you like to make your workflow more efficient with step-by-step instructions on how one of the experts here might model your geometry?
GRANTRICKARD
Observer
Observer
That would be really helpful!
TheCADWhisperer
@GRANTRICKARD
Open the Attached file.
Edit Sketch1 and examine.
Double click and change the 10mm height to 246mm.
Finish sketch.
Undo
Go through the Timeline step-by-step.
I will be back later to answer questions you might have...
