Problems organizing inserted components
rjeAT6XG
rjeAT6XG
I'm trying to organize a design that has inserted components and sub-assemblies.  When I try to drag the inserted compnents to the sub-assy that I want to use, it doesn't move.  What are the rules to moving inserted components?  Is there something I'm missing?
davebYYPCU
Yep,
In this file, you can’t modify a linked component, or sub assembly.
Adding a new file to the linked subassembly is modifying it.
You need a plan B.
Might help....
jhackney1972
Open the external sub-assembly directly.  Add your external components to it as desired, save, close and return to top level assembly and accept the pending Update.  Since you already inserted some external components into the top level, you may have to Remove them, and follow the process above.  In doing this you may lose some assembly Joints that have to be replaced.
John Hackney, Retired
