Hi @paul.clauss,
I looked into it a bit more and it looks like you are correct - the Intel graphics driver is integrated into the Mac OS and should have been updated when you updated your OS.
Thx!!
Moving forward, I have a few thoughts. Firstly, you could try working through the procedure outlined in THIS ARTICLE, which will have you toggle offline mode and clear your local cache. This may help address the issues you are experiencing with uploading or saving Fusion designs.
Cleared all the cached file from F360 dropdown menu, and still crashes very often.
If that does not work, you could try manually clearing your upload meter and browser cache files. To do so,
- Close Fusion 360.
- Browse to ~Library\Application Support\Autodesk\production\JobManager360\<ID> (look for latest modified)
- Locate the jobs.json and the jobs.json.lck files and delete both.
- Restart Fusion 360 and review the Upload queue. The deleted files should be recreated when Fusion is ran.
Seems the directory structure has changed, I cannot locate JobManager360 sub-directory:
To clear the browser cache:
- Close Fusion 360.
- Locate and delete the following directory: ~Library/application support/Autodesk/Autodesk fusion 360/{ID}/PLM360Cache (Open Terminal and enter open $TMPDIR/Autodesk to locate the BrowserCache directory).
- Re-open and test Fusion 360.
Also no luck with this directory...
If none of the above seems to help, please attach your diagnostic (application) log files to your next forum post using THIS PROCEDURE. You could also try performing a clean uninstall and then reinstalling Fusion 360 - due to the recent Fusion updates and your OS update this may help straighten things out!
Here's the Graphic Diagnostic :
[GPU Information]
GPU Device: Intel HD Graphics 4000
GPU RAM: 1536 MB (Integrated card)
GPU Driver API: OpenGL
[Graphics Effects Settings]
Use high-resolution graphics: Off
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
On
and my log file (see attachment)
