Extruding at an angle.
Hi All,
Having a bit of a problem creating a shape and can't find any info on this.
Attached is the solid I need to create. Basically I need to remove the part on the right of the line.
Tried extruding in a few ways but didn't manage to achieve what i needed. I also tried sweep, which sort of done what I wanted but not quite.
I think I am missing something here...
I also need to place some sketch on the inclined face and extrude it strait not at the angle of the face.
In essence I need to create something akin to the structure of an HV electricity pillion upside down.
I would appreciate some tips on this.
Thank you.
Best Regards
                Luis
TheCADWhisperer
@Anonymous wrote:
1. Attached is the solid I need to create...
2.  I need to create something akin to the structure of an HV electricity pillion upside down.
1. Actually, what you attached is an image file, not a Fusion solid body file.
2. Can you post an image of a "HV electricity pillion" example?
I probably should have named the attached solid as "wild...guess" rather than "best guess".
jan_priban
for skew faces use Draft feature. In you case, project your line into appropriate face/plain (or create new construct plane). Then extrude/sweep appropriate profile (face portion).
Regards
Jan Priban
Autodesk Fusion team
Hi Jan,
Thank you, that works.
Best Regards
                 Luis
