Problem with Web feature
10 REPLIES 10
Message 1 of 11
JHRendon
648 Views, 10 Replies
Why can't I make a web in this part?
10 REPLIES 10
Message 2 of 11
laughingcreek
in reply to: JHRendon
does look like it should work. hard to tell from just a pic. can you export and attach your .f3d file?
have you tried one line at a time to see if a particular line is causing the problem?
Message 3 of 11
is that a solid, or unstitched surfaces?
Message 4 of 11
JHRendon
in reply to: laughingcreek
Here it is. 🙂
Idk what's the problem.
Message 5 of 11
JHRendon
It is a solid body. 🙂
Message 6 of 11
TheCADWhisperer
See Attached.
Message 7 of 11
laughingcreek
you must have fixed it, works fine for me-
Message 8 of 11
JHRendon
You're right, now works! idk what was the problem 😞
Message 9 of 11
JHRendon
in reply to: TheCADWhisperer
Thanks! 😄
Message 10 of 11
TheCADWhisperer
I did not have a bottom (or top) to extend to cap the feature.
You must use Depth distance rather than Extend To  I mean rather than To Next.
Message 11 of 11
JHRendon
I tried both options and same error, idk what was the main error.
