problem with the surface of the candy cane
Hi everyone, I'm trying to make a candy cane, and I followed a video tutorial about it, but in the moment in which I have to use the "SWEEP" command to create the colored stripes on the surface of the object, I have problems and I can't understand where I'm wrong, I attach the link of the video tutorial and the video of how I made the object, hoping to understand where I went wrong.
thanks
video tutorial
my candy cane
artemSIV
Hello. At the last stage, you mixed up the profile and path
HughesTooling
Your design has more of a hook and the diameter of the sweep is bigger relative to the path (your cane ends up a bigger diameter). because of this the line is longer so when you add a twist you get self intersections, try making the line shorter and the circle a smaller diameter.
If you're still stuck, export your f3d file and attach here and someone will help.
Mark
Mark Hughes
Owner, Hughes Tooling
artemSIV
Are you seriously? Have you watched the attached video? there the profile and the path are simply mixed up
HughesTooling
@artemSIV  OK, yes, got mislead by the picture in post #1 where he does have the path and profile correct.
Mark
Mark Hughes
artemSIV
and really. some kind of confusion comes out, I'm sorry, I hurried
