How to align "amorphous" sketches?
mikep84463autodesk
Observer Observer
mikep84463autodesk
Observer
Observer
Newbie here.   I created a sketch using Fit Point Spline, pictured below:
Then, I created a second sketch of this same form, but slightly larger, using copy/paste + sketch scale.  Then I aligned them visually ("eyeballed it").
Is there a tool-based way to do this alignment so I don't have to rely on my eye?   I tried the Align tool but it appears to only work sketches where the center is well-defined.
Thanks.
TrippyLighting
Your splines have way too many fit-points.
You can offset a spline in the sketch, but I usually don't recommend that.
You can also simply extrude a surface form the original spline and offset the surface.
mikep84463autodesk
Observer
Observer
Offsetting the extruded surface worked perfectly, thanks!
