help design a pattern
fahef77309
fahef77309
hello everybody
im a total begginer in Fusion 360 and i need your help please
i want to make a pattern of honycomb that extrude 0.3 mm above surfuse but inside a specific shape, every time a diffrent shape.
im faceing couple of problems:
1. the shapes is very small like 0.3 mm each one so i end up  up with hunderds of bodies
2. how do i "cut it" in the shape that i want?
3. is theres a way that i can use the same pattern and just"cut" the sape i need every time?
im attaching 2 files the first is example of the pattern, the scond is i mark in purple where i want the patter this time,
thanks in advanceto anyone that helps
LeonardoBN
Hi @fahef77309.
Did you make that honeycomb pattern on Fusion? It would be nice if you have this pattern tidy and in one body (maybe in another design); it will help you later as you want to use it repeatedly.
Do you want to make this only on flat faces?
If you want to go through this way:
1. You can place your pattern over the body you want to texturize (look for ways to move and align entities)
2. Extrude the faces you want the texture, and instead of Cut, select Intersection. It will keep the honeycomb only in that profiles and remove the others.
This will work for flat faces.
da67b5fc-4c28-4754-a74f-5f0312dc2208,640,650
Leonardo Brunelli do Nascimento
Chemical Engineer
