Problem with stitching surfaces
Florian__
Message 1 of 10
Florian__
I tried to stitch two faces together without success.
Do you know what I can do to fix that?
The part is attached
Replies (9)
Message 2 of 10
TheCADWhisperer
Uhmm, which two surfaces?
Message 3 of 10
Florian__
Thank You for your message. I added the video
Message 4 of 10
TheCADWhisperer
Change the seam for the Revolve.
See latest file Attached in previous response.
Message 5 of 10
Florian__
Thank you! Sometimes Fusion is really weird. How could you find that out? Is there a reason behind?
Message 6 of 10
Florian__
Do you have an idear how to create a radius in the marked areas?
The part will later be deepdrown from plastic.
Message 7 of 10
KristianLaholm
The first problem with Stitch was that you hade selected the full sketch profile for the revolve not only the line you wanted (Left original, Right only the line).
I created a curved edge by before stitching using Pipe (solid) to cut away parts of the surface.
Using Surface Patch to fill the gap and tangent connection between selected edges to get the best surface possible.
Attached my f3d file have a look 🙂
Message 8 of 10
Florian__
Great Help Kristian!
The part will be produced by deep drawing.
And will constit out of two parts.
Do you know how to improve the surface Quality? Do I need another guide rail on the sides or have to set some conditions?
The other question is how to create such overlapping. Would you do it with the loft or later?
Message 9 of 10
KristianLaholm
I'm not familiar with the manufacture process or good enough at Fusion to help to all the way.
The few thing I have picked up on surface is to keep a minimum of guide lines and points to get a smooth surface.
Message 10 of 10
Florian__
okay. Thank You!
