Program freezes when I scale my drawing up
MariusBaard
MariusBaard
I have made a derive of my parts, then did a drawing, but every time I try and scale the drawing up the program freezes up.  Please help.
Here is a link to my file:
https://a360.co/3i83FrB
kris_berg
Hi @MariusBaard ,
Thank you for sharing your drawing.  I am able to reproduce your hang and will enter a defect.  Unfortunately, I am not aware of any workarounds.  I will let you know when I have updates on your issue.
Kris Berg
Senior Software Architect - Autodesk
MariusBaard
Hi @kris_berg
Thanks for the reply, I don't know what happened there, but found a workaround.
Delete the drawing and insert it again seems to work.
Thanks for the support
spope0884
Having a similar issue. Using Fusion 360 in my classroom. Students (and me) are experiencing freezing when adding a drawing to a title block. It has happened at the exact same moment at each instance. The title block has loaded, the base view is still attached to the mouse, when the scale is changed - it freezes. Absolutely nothing on the screen is operable. Closing the browser, shutting down the computer... after logging in again - it's on the same frozen screen. It seems to resolve after 7-8 hours of not being usable - from class time to after dinner time is a typical spread of freeze.
