Problem with Step-By-Step Tutorial/Form/Part Design
Hi all,
i´m new here and i´m not an english-expert, so please excuse my bad english 😕
I´m try to do the Step-By-Step Tutorial/Form/Part Design. At the step 15/18 i have to drag the line out of the solid, but it doesn´t work 😞
I can´t pull the line, pleas help me.
Best regards from Germany
Pascal
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
I went ahead and tested the tutorial on my machine and got the same error and actually noticed another one in the meantime. I think it has to do with the constraints that the offset command creates as you will notice that the tutorial video looks much different than the sketch constraints that are in place when using the offset command. I will go ahead and log this with our development team. The workaround in the meantime is to go ahead and delete the offset constraints and then pulling the edge will work. To do so, highlight the two constraints (looks like a white thumbs up near the top of the sketch. See pic below), and then press delete. Then you should be able to drag the edge. Let me know if that works for you!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Hi James,
thank you for welcome!
Your way works well, thank you very much.
I´m so flashed by Fusion360 ... unbelievable!
Great to be part of this Community!
Pascal
AHHH...Thank you ,i spent almost (it felt like)an hour trying this and that....
