Step-by-Step Tutorial : FORM->Part Design
I'm trying to do the step-by-step tutorial:  FORM->Part Design.   At step 15of18, it says "...Now select the longest edge of the offset sketch and drag it outside the body."   I have tried every which way I can to drag this edge but it won't move - what am I supposed to do??
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Looks like this is a hot topic right now. I went ahead and posted my answer to another forum post found in the link below. Let me know if that solution works for you (let's try to consolidate these threads and just work in the other one if there are any more questions).
http://forums.autodesk.com/t5/design-validate-document/problem-with-step-by-step-tutorial-form-part-design/m-p/6006615/highlight/false#M43802
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
