Problem with Sketch folder :(
Hey folks! 🙂 I signed up on the challenge of Fusion 360, and I almost finished my project, but after checking the Youtube channel I discovered a few practices that I didn't apply throughout the proccess, and although there are 15+ unique parts, their sketches are in only one folder (they are not in the component folder)
My question is, although I didn't follow the tips accordingly, can still be accepted?
I am looking for an answer, as I am a bit worried since I invested much time in that and my renderings are almost done.
Hugs
TrippyLighting
Well, yes, that still works and you have a valid model
It's just  ot the best practice going forward.
For the next project I'd suggest you start follwing Fusion 360 R.U.L.E #1 - Create a component and actiate it.  Activation for newly created documents is automatic.
Everything created after that activation will be created in that component.
If you want to edit another component, activate it before doing so.
Oh thanks for the quick answer 😄 definitely seems to be the main rule. Fortunately some of the sketches I referenced then with offset plane and not with another body, so maybe I can drag them and dro them in the correct component.
Since I have a bit of time left maybe I can even copy the sketches one by one and redo the features correctly.
Anyway, it wont be my last project 😉 Hugs and thanks again!
