Problem with "mirrored" sketching
- Mute
- Permalink
- Report
I'm trying to go back into each one of my sketches and correct some problems with them referencing a sketch that's actually not part of the current component.
I select the Sketch, choose to Edit Sketch, and then draw a new line in that sketch. But the line that gets created is NOT in the location where I drew it. Rather, it pops up on the exact opposite side of the vertical axis. I tried rotating the whole sketch around the vertical axis, so that I was seeing it from "the other side", but drawing a new line there causes the same issue, the line actually appears over on the other side of the axis, as if it's a mirror of the line I intended to draw.
I have NEVER had this happen previously.
In the image below the line I am attempting to draw is on the left side, the black line with the small square at its bottom, and the line that ACTUALLY gets drawn into the sketch is the blue line to the right with the circles on either end.
This even happens if I create a brand new sketch and try to draw something in it. I always get a mirror image of what I'm trying to draw.
What in the world am I doing wrong?
