I created double body while I intend to create only one
I was sketching on a component that I had duplicated from similar component (but different component). Then I sketched on the face of the component. But what that I get is the new body is duplicated on the other component that is similar with the component which I sketched on the surface of that. I am a beginner of Fusion 360Note that the body that I created automatically have duplicates on the face of other component (which the component is duplicated from other component where I sketched on it), but it is definitely different component thoughNote that the body that I created automatically have duplicates on the face of other component (which the component is duplicated from other component where I sketched on it), but it is definitely different component though
davebYYPCU
When you Copy  / Paste a Component,
anything after that (new body) will happen in both components.
Copy / Paste New, will allow new parts to either component - that does not transfer over.
Might help....
Thank you, but can I fixed that without getting back to the beginning? i.e. I likely had my components copied not in 'New Paste' way. Is there other way to 'unlink' them?
mavigogun
Maybe.   Sometimes I'm able to separate and capture work by Copying Components into another design, or another design without Capture of Design History enabled, then copy the product back as a unique Component.   Depending on the interconnections, Historied Components may bring Timeline error warnings, and those Dispensing with History may require later duplication of sans-History locked Sketch Elements.
