Problem With Joint on Delta 3DP
samuele.carpi
Message 1 of 9
samuele.carpi
Hello, I'm build a delta movement for a 3D Printer. I make the joint but when I enable contact something go wrong.
Someone Can help me? Thanks!
https://a360.co/3xfxmB3
Replies (8)
Message 2 of 9
TrippyLighting
I've not yet looked at your design, but do NOT use contact sets.
You'll have to export your design as a .f3z or .f3d if you want us to examine it.
I am assuming you are using a free subscription and that does not allow us to download your design.
Message 3 of 9
samuele.carpi
Thanks! Yes I use a free version.
Many thanks!
Message 4 of 9
TrippyLighting
Before you do anything else you should fix the 10 waring icons in your timeline.
Message 5 of 9
samuele.carpi
Many Thanks! Here the file Warnings Free 🙂
Message 6 of 9
TrippyLighting
I can see that the contact set hiders of prevents movement. So disabling it will free everything.
What is it you are trying to solve with the contact set ?
Message 7 of 9
samuele.carpi
Yes, if I enable contact I can't move the delta sistem.
I wish move the delta cinematic with contact enable because have do add items on the effector and I wish see if the elements I add prevent some movement of the system.
Hope you understand my bad English.
Thanks!
Message 8 of 9
TrippyLighting
No worries, your English is fine!
I don't think that is going to be successful. Contact sets work best on very simple situations. However, an assembly with several ball joints will likely overburden the contact set solver.
Message 9 of 9
samuele.carpi
uhmmmm so the solution is move the delta cinematic and locks if there is some contact form parts?
