Message 1 of 14
12:24 PM
- Mute
- Permalink
- Report
I need to make a recess/pocket to receive the head of a bolt. I have the through hole for the threaded shaft of the bolt in place. When I use the circle command and establish the center and diameter of the recess on the front face based on the center point of the through hole, it shows up on the rear face and therefore I cannot extrude the pocket I need. The front face is curved, not a flat face. I don't see why that would be a problem.
Suggestions?
