Problem with drawing even with simple part!
janus2
Message 1 of 8
janus2
Hello!
For my other problem with a drawing I haven't got an answer yet.
So I have now reduced it to another, simpler, example!
In the sketch I can define everything with dimensions and angles.
Then an extrusion. No problem.
But in the drawing I cannot define the angle positions of the slots or the round section.
How can I create a drawing for my manufacturer?
The real part is much more complicated with many circular patterns. Without angular dimensions, drawing creation is impossible.
Is there a trick or workaround?
Thanks a lot
Jan
Replies (7)
Message 2 of 8
wmhazzard
In the 2D drawing space, under dimensions use angular dimension and tap the space bar to get point to point angles.
Message 3 of 8
janus2
Thanks for the quick reply!
That works for the arc. But the dimensioning is not very clear. The construction lines are missing.
But I can't find a central point for the slot. How do I define the angle position of the slot?
Jan
Message 4 of 8
chrisplyler
Make another sketch. In that sketch, project in the three construction lines from the first sketch. Turn those three projected lines into construction lines themselves.
Then in the Drawing, turn on the visibility of that sketch, and dimension the angles between those lines.
Message 5 of 8
g-andresen
Hi Jan,
1. change line character in sketch > construction to full
2. activate sketch in drawing space
using of sketch elements for dimensioning in drawingsusing of sketch elements for dimensioning in drawings
günther
Message 6 of 8
janus2
Thank you so much for your help!
I didn't know you could turn on Sketch and use it in Drawing. This helps me a lot.
But it's a shame that Fusion 360 is the only CAD program on the market that doesn't have drawing tools in drawing. It's really paradoxical. The tools are available in sketch mode. It shouldn't be so difficult to transfer them into drawing.
The real part is much more complicated. I also need some section views. They also have their problems.
If I don't get there, I will export the part as STEP and create the drawing in my old SolidEdge.
Many thanks again
Jan
Message 7 of 8
g-andresen
Hi Jan,
in the idea station there is among other things this entry.
Vote for it or create your own.
günther
Message 8 of 8
janus2
Hallo Günther!
A good idea.
The one you specify goes in a different direction: change/extension of the existing drawing.
I would be happy if I could dimension the existing one.
But I have found some that go in the right direction.
Thanks for the reminder
Jan
