Problem with converting a Stl to a Body in Fusion
ianhughes7UFVF
ianhughes7UFVF
Hi
I am converting a stl to a body in fusion. It converted so far but it still wont become a body.
Is there something I am missing.
Regards
Ian
JeromeBriot
The mesh is not fully closed so Fusion 360 creates a surface instead of a solid body.
Use Meshmixer to repair the mesh. Go to the menu Analysis > Inspector and click on Auto Repair All.
Export the repaired mesh and now Fusion 360 will convert it to a solid body.
See attached file below.
ianhughes7UFVF
Hi
Thanks for that.
I better download meshmixer and learn how to use it.
I appreciate the direction.
Regards
Ian
TheCADWhisperer
For geometry that simple I would remodel from scratch rather than use coarsely faceted planar triangles in any of my designs.
ianhughes7UFVF
Hi
I agree and I am more than capable of it now.
The file is for a chap who has a set of stls that are simular to what I have already created. He wants to mix these stls with stls of parts that I have already done.
I didn't want to have to redo all my work.
But I agree. I am now in the mind set that I would rather create things from scratch if I can now.
Regards
Ian
TheCADWhisperer
I didn't search for the opening - but if found, you could probably easily use a Patch and then Stitch in Fusion rather than bothering to go to MeshMixer for this simple part.
