Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Problem rendering a decal on a cylinder
12 REPLIES 12
Message 1 of 13
robduarte
1826 Views, 12 Replies
Hi, I'm trying to get a decal to render on a cylinder and I'm seeing a weird anomoly on one side of the cylinder. I've tried this on different designs, including one that just has a single cylinder and any image as a decal. I've tried on MacOS and now on Windows. Rendering in canvas, rendering locally or on the cloud all have the same issue. Please see the attached screenshot.. the problem, in case it's not obvious, is the wavy line. It seems to happen regardless of the size of the decal, how much I stretch it, etc.Thanks for any help..
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
12 REPLIES 12
Message 2 of 13
innovatenate
in reply to: robduarte
That doesn't look like the correct behavior! Thanks for reporting this! Can you share the design with us?
Nathan Chandler
Principal Specialist
Message 3 of 13
robduarte
in reply to: innovatenate
Sure, here is the public link: http://a360.co/1WzxF2Y
I don't know if there's much value in this particular design since the same thing happens on either OS, with any cylinder and any image decal as far as I can tell.
Rob Duarte
Twitter | YouTube
Message 4 of 13
scott.mayson
I am also having same problems. I have a decal that crosses several chained surfaces which worked on previous version but is only rendering on a single surface now
Dr. Scott Mayson
Industrial Design RMIT University, Melbourne Australia
scottmayson.com
Message 5 of 13
brucehuang
in reply to: scott.mayson
Hi @robduarte, thanks a lot for reporting the issue. As I know, there are some internal bugs have tracked this issue. The issue usually happens when wrapping a image around a periodic face (like cylindrical or conical face). The texture distortion will be big at the merging place. We are sorry that now there's no very good workaround for this. One possible approach may be split the image into two parts, and place them on the half periodic faces.
@scott.mayson, could you please have double check if it really worked for old versions? It should be a known bug.
Bruce (Fusion Development Team)
Message 6 of 13
scott.mayson
in reply to: brucehuang
Hi @brucehuang here is a screen shot of the issue. Decal "camoflage pattern" applied to top surface of component.
And when i roll history back to "Form1" then directly roll history back to last Decal with out any editing it looks like this:
Dr. Scott Mayson
scottmayson.com
Message 7 of 13
brucehuang
Hi @scott.mayson, thanks for sharing the details of your issue. From the snapshots, it seems like a entity tracking issue for converted BREP faces from form feature. But I can confirm that it should be different issue against what @robduarte mentioned. I will try to reproduce it and log a bug tomorrow. Thanks!
Message 8 of 13
I've the same problem with a decal on a cylinder surface. How can I do?
Message 9 of 13
Hi Rob, I have the same issue applying decals to cylinders. Was a solution to this problem ever discovered?Decal_Wrap_Issue.png
Message 10 of 13
robduarte
I haven't tried it again since I originally posted, but if you're still having the issue I'm guessing it hasn't been fixed.
Rob Duarte
Twitter | YouTube
Message 11 of 13
Hi there - was this ever supposably fixed? I am still getting the same problem no matter what settings I change. This is only apparent on a final render output. In the model space the decal seems to be applied/ showing perfectly fine. Any help would be greatly appreciated!
Ben
Message 12 of 13
glzj123
I have the same problem. Does this not solve the problem? Always.왜이러냐아아.png왜이러는걸까요.png
Message 13 of 13
Is the Length and Width of your Image good to wrap the whole Bottle...? And in the bottom where we edit the image, the options of Horizontal and Vertical Tile are on..?
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Technology Administrators
