Problem Obtaining Plane Reference
Message 1 of 15
Dear all,
I would like to create a rib on my component but struggle to position the rib accordingly.
The goal should look like this:
I for some reason cannot position the rib-line.When I insert the rib I get the error: The Rib cannot be created. Ensure profile curve can intersect body.
When I draw the line, i cannot fully define it and it remains blue. It does not find an anchor point on the upper connecting part.
Accepted solutions (3)
Replies (14)
Message 2 of 15
mavigogun
Sharing the file will greatly aid in lending assistance- File>Export>Save to your local machine>Attach to your reply here.
Message 3 of 15
Marco.Takx
Hi @Anonymous,
I made a quick model with a rib.
At the pictures, you are showing it looks like you have created a sketch on the correct plane.
Maybe this example helps you creating your rib.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 4 of 15
Hi there
i just attached the file as per your request 🙂
Message 5 of 15
thank you! But how can I apply an anchor point on the upper component part. I can connect at the lower end, but the upper end is free floating and not defined.
Message 6 of 15
Marco.Takx
Hi @Anonymous,
Your problem is that there are 2 bodies.
You have to combine them first.
Marco Takx
Message 7 of 15
I did that and combined them but still the upper end of the line remains floating and does not find an anchor point on the round component. hm...... i attached the file. Would that help if you have a look into it directly? so appreciated (just learning my stuff 🙂
Message 8 of 15
Marco.Takx
Hi @Anonymous,
Check my file in the attachment from the previous post.
Marco Takx
Message 9 of 15
davebYYPCU
New plane on 3 points, use sketch 2 and Sketch 15.  Plane is side on to the intended rib.
Project > Intersect the two aligning edges, then sketch the line to join,
Rib works as expected with this preparation.  Set thickness as desired.
Might help....
Message 10 of 15
mavigogun
Couple observations: "obey" Fusion Rules #1 & 2:  Create Components and Name Your Stuff.  18 Sketches, none labelled, and zero components.
Message 11 of 15
Can you maybe upload the updated project please too?
Message 12 of 15
davebYYPCU
No Problem
Message 13 of 15
lichtzeichenanlage
I agree with Rule #2 but unless the design only contains one part there is no need for a component. The root component will do the job.
Message 14 of 15
mavigogun
Now, I suppose- but I've had plenty of opportunity for regretting stuff orphaned in the root folder as a design progresses, expands.    I figure it doesn't hurt as a mater of practice, and benefits if developed as reflex.
Message 15 of 15
lichtzeichenanlage
If you plan to just modle on part, because it's e.g. part of another design, it will "hurt" if you're creating components by default, because whenever you insert (not derive) the design, you'll end up with a unnecessary component in the target design.
On the other hand, if you don't create the default component and you'll want to add more components to this design, just create a new design, insert the existing, break the link and you're "clean" again.
Starting with a default component is IMHO against the points in Rule #1.
