Prismatic Option
Prismatic Option
APOSTOLISZEV
Message 1 of 12
Prismatic Option
APOSTOLISZEV
I am trying to turn my STL file into a Solid body, but the prismatic option doesn't work properly.
I don't want the faceted option, beacuse to want to offset my object.
Does anynone have any idea how I can make the uploaded STL solid body?
Thanks a lot,
Apostolis Zevgaras
Replies (11)
Message 2 of 12
wmhazzard
Solid model the part from scratch, use the stl for reference only. Converting meshes to solid does not work well for many models so if it fails, don't use it. If there were no threads on it then it might have worked.
Message 3 of 12
APOSTOLISZEV
I just want the thread part, because it fits perfectly in the application I want.
So there is no possibilty that i can make it solid?
Message 4 of 12
Joshua.Aigen
If your just looking to use the threads from the STL then model the part in Fusion, then change it to a mesh, then use the combine command to unite the two meshes.
Joshua Aigen
Workshop Supervisor
Message 5 of 12
APOSTOLISZEV
Ok thanks a lot.
But there is no option to make it prismatic?
Message 6 of 12
Joshua.Aigen
Sorry I didn't take the time to look into the STL file, but now that I have I see why my suggestion might not work. I tried repairing the mesh as there are some nonmanifold surfaces and the result looks to already degenerated to the point where the threads would no longer work. All the Mesh to Brep conversions I have done threads have never remained useable after the conversion. The solver is not to the point where it can interpret the spiral and maintain it, even my experience with Geomagic a software meant specifically for this type of application it would be very labor intensive to create all the face groups and specification to have this work. You are much better off remodeling the part. Here is a shot of just the repaired surface no conversion.Forum.JPG
Joshua Aigen
Workshop Supervisor
Message 7 of 12
Joshua.Aigen
I'm trying to do a prismatic solve on only the outer threaded section using a plane cut on the mesh body. But I was thinking if this is a standard fitting or coupler would you be able to find a step file on McMaster-Carr or similar sites?
Joshua Aigen
Workshop Supervisor
Message 8 of 12
APOSTOLISZEV
Thank you a lot for your interest.
I have find the STL file from Thingiverse.
URL:
https://www.stlfinder.com/model/1-2-m-x-1-4-f-adaptor-fitting-g4hZRsKD/1952454/
Message 9 of 12
HughesTooling
Attached is a 1/2 to 1/4 NPT adaptor I found on McMaster-Carr that seems to be the same thread, the thread in the STL is not modelled correctly anyway. Maybe you can modify this part.
Picture of the solid model and the mesh.
Mark Hughes
Owner, Hughes Tooling
Message 10 of 12
APOSTOLISZEV
Thanks a lot, that was very helpfull.
Message 11 of 12
APOSTOLISZEV
Hello Mark,
I am trying to convert 2 mesh files into a solid body. I insert the mesh file -> then i Generate face groups -> then i convert the mesh. But when it comes the time, my spiral is destroyed.
I want a 53mm male-female connector.
Does anyone have a solution to this problem or has a 53mm male female connector?
Thanks a lot.
Message 12 of 12
APOSTOLISZEV
Hello Mark,
Thanks a lot.
