Constrained for some reason
ninthabandit
ninthabandit
For some reason, I can't dimension any of those lines, add an angle dimension to the line above the constructed line, or anything. If I try it says over constrained. Anyone know why I am constrained? File attached. Thank you!
EDIT: I can't actually edit any of my dimensions anywhere. Not sure why.
jeff_strater
the answer is in the error message - your sketch has some conflicts.  In particular, there is one tangent constraint that seems to be a problem:
If you delete that, you can then edit dimensions.  I did not investigate what, particular problems the tangent constraint is causing
Jeff Strater
Engineering Director
TheCADWhisperer
I recommend that you add most of these Fillets as features rather than as sketch elements.
