Sorry but I cannot diagnose your file, I just don't have several hours to dig into this. I opened it and found that almost nothing drags, so I looked at joints.
Couple of things I notice that might be important:
- There are hundreds of joints. Quite a few rigid joints. Is it possible you added a rigid joint between things that move and things that are intentionally rigid?
- Most of these rigid joints would be better replaced by a few rigid groups.
- When you suppress joints a warning appears about joint conflict.
- So I believe in all of this you have a joint conflict.
Rule of thumb: If it will not parametrically change size, and it's a sub-assembly with no motion, make it a Rigid Group. This will cut down on the possibility of joint conflicts.
I also notice that you appear to be using Joints to position parts, i.e. lock down degrees of freedom. Remember that joints are there to define motion first and foremost. There are other tools such as Align that let you position parts and then apply Rigid Groups.
I found that if you suppress Rigid 73 you get the "slider" component and it's mate on the other rail to move. Work your way through the connections to that component, it goes up through the bracket to the chain, until you find the one joint that is locking your motion.
You can:
- Right click on a Joint in the browser and pick Select Components.
- Right click on a component and pick Select Referencing Joints.
- This can help you work your way through the model until you find the one conflict.
Some more feedback to help your modeling, this may not be related to the problem you are reporting, but will speed up your model:
1. Capture Position. I notice that you have many of these in your timeline. Tip: if you move a part more than once, and accept more than one Capture Position, only the last one matters. You can delete the previous ones with no penalty.
2. Many yellow and red warnings in your timeline. This indicates a sick or failed feature. It's best to eliminate these errors as they happen.
Hopefully by cleaning up all the extra rigid joints, and thus making logical sub-assemblies held together by rigid groups, you can more easily diagnose this, and also more easily finish your design.
Please find attached a paper from AU 2015 about Joints.
Let us know how it goes, I will watch this thread and I'm sure other forum folks will tune in with even better advice.
Phil Eichmiller
Software Engineer
Quality Assurance
