Press Pull Odd Behavior
Message 1 of 14
Hello
I am having a problem with push/pull in a tutorial. Attached is a screen capture. Please can you help. I am sure I am doing something wrong.2017-06-25_20-54-45.png
Replies (13)
Message 2 of 14
saito.kh
Autodesk Support
Autodesk Support
Hello @Anonymous,
Thank you for posting in the community!
I am sorry to hear that. Can you please let me know which tutorial you are trying?
Since I could take a closer look at your problem on my machine, would you mind sharing your design with me?
I would be able to have your design on this thread or in a private message, either by attaching the file or creating a public link - see the below how to create the public link:
https://knowledge.autodesk.com/support/a360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-sh...
It would be also appreciated if you would record how you operated by Screencast; this would help me troubleshoot this behavior!
Thanks!
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 14
thanks for replying to my problem.
The tutorial is from Lars Christensen.
I folowed the tutorial exactly as he did, but dont have the same result.
Attached is a picture with lars giving the tutor. It is on youtube. Perhaps his version is older?
Message 4 of 14
Hi @Anonymous
I went through the tutorial.
I think version is not a problem.
I couldn't understand what exactly the problem is ,from the screen shot.
Can you specify exactly what you weren't able to do?
Message 5 of 14
Hello
Yes the front pipe is red and has lines through it. Push/pull dies not want to extrude. It is supposed to be 28 mm but does not go beyond what is shown in the picture. Why is it red? It must be a fault. I did a fee repeats of the tutorial snd get the same. I also tried extruding from the front and get the same result. It is almost as if only can have one pipe?
Message 6 of 14
wilkhui
Hi Andre, welcome to the forum!
Are you able to attach your file as @saito.kh mentioned?
Sometimes a small, unintended action can lead to unexpected behaviour and being able to look through your file will allow us to discount that.
Cheers,
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
Message 7 of 14
You might be interested in this Screencast:
Push/Pull
I am frustrated with this. the extruder on the front face worked 100%, now I tried doing the same on the side of the box and it does not want to
perform the extrude. it shows red .Must be something I am doing wrong.
I followed Lars Christensen tutorial exactly up to this point.
http://autode.sk/2tMpzsi
Capture and Share Your Expertise
Autodesk Screencast lets you capture your workflows to easily create powerful and
engaging learning materials. For more information visit:
https://screencast.autodesk.com/
Message 8 of 14
Hello
I sent a screen cast.
Hope you could assist please
thank you
Message 9 of 14
wilkhui
Hi Andre, thanks for sending the video, it helps!
Can you also attach the .f3d export of your file?
Indy
Product Owner - ASM
Autodesk, Inc.
Message 10 of 14
HughesTooling
Do you have a section analysis enabled? I have seen similar if you use slice in a sketch and leave it enabled when you close the sketch as well.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 11 of 14
Will have a look if it is enabled. But never used it before.
Message 12 of 14
HughesTooling
Looking at your screencast you have an analysis folder in your browser, it is only created if you have a section analysis in your design so I suspect that's the problem.
Here's your screencast and you can see the section analysis folder.
Mark
Mark Hughes
Message 13 of 14
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous, @HughesTooling, and @wilkhui,
Thank you for all the inputs and updates! Glad to know this was resolved.
Cheers,
Kanehiko SAITO
Message 14 of 14
Thank you for your help. I am sure I will need your expertise in future.
