Press Pull - I want to increase/decrease the diameter of the inner (smaller) hole.
shiv.kmr003
Message 1 of 11
shiv.kmr003
The current diameter of the inner hole is 0.266" and I want to increase it to 0.315" I am able to use the Press/Pull feature (offset) but I'm not able to get it to exactly 0.315". I'm typing the value (0.049") in the box that pops up but there seems to be a formula that I'm missing 🙂. I've tried using half of 0.049" thinking maybe I should enter the radius instead of the diameter, but that's not it either.
Replies (10)
Message 2 of 11
jhackney1972
I think you will have success using the Offset Face command.  It is located under the Modify menu.
John Hackney, Retired
Message 3 of 11
davebYYPCU
How was it made originally,
Edit Feature, and change the value used to make it.
Might help....
Message 4 of 11
shiv.kmr003
@jhackney1972 Thank you for your reply. I believe the Press Pull automatically chooses the correct operation. Nonetheless, I did try the Offset Face command directly, selected the face and added the appropriate number.
the current diameter is 0.266"
I want it to be 0.315"
So I entered -0.049"
What I get is a diameter of 0.364" 🤔. Same as what I get when I use Press Pull.
I must be missing something really obvious, but I'm at a loss.
Message 5 of 11
shiv.kmr003
Thank you for your reply @davebYYPCU,
It was made from a sketch originally and then using the rectangular pattern command (the sketch only have one)  on a body I made multiple.
Are you saying if I modified the sketch, the multiple copies in the body will change?
Message 6 of 11
davebYYPCU
Yes,
and your result is 0.049 too big, Use half of 0.049.
Might help....
Message 7 of 11
simsworx
What your stating is what I would expect. Consider this - Your hole is .266 dia. You tell it to offset the face -0.049, making it larger. The .049 is offset from the entire circle, adding twice the offset to the diameter. End result, .364.
I believe Push/Pull and Offset face will accept formulas, try entering -.049/2 in the value.
Message 8 of 11
shiv.kmr003
I know I tried this before I posted to the forum. But you're right, it needs the radius and not the diameter as the offset.
@davebYYPCU Thank you.
Message 9 of 11
shiv.kmr003
Thank you @simsworx! I'm positive I tried half before posting to the forum. But yes, half actually worked.
Message 10 of 11
shiv.kmr003
Yes, it all makes sense now. If you read the very first message I posted, I had tried half the value (but obviously, I must have made a mistake), and since that "also" didn't work I was stumped :0. But now I know that I surely got something mixed up.
Thank you for all of your help and explanation. Much appreciate.
Message 11 of 11
shiv.kmr003
@davebYYPCU wrote:
Yes,
Wow, that's cool. Thank you for the tip.
