Simplifying complex lofted body
zcqsdmd
zcqsdmd
This is my first post and I am a newbie at FUSION 360 and CAD
I am trying to make something like this shape (also see the STL file here): https://www.thingiverse.com/thing:5031629. I need to make it from scratch as the original is a 1mm thick mesh (STL) and I need it to be 2mm thick for strength purposes.
I have used a loft to create the basic shape. But I am struggling to create the flat section on the funnel portion like the one shown on the STL file.  Instead the loft is conforming to the curvature of the circle. Do I need to use guide rails? I have attached my attempt as a .f3d file.
I have done curvature analysis as suggested by someone else on this forum which shows I need to simplify the curvatures so I can shell the body to a thickness of 2mm. I can shell to a thickness of 0.000001mm which is not adequate.
Any help would be much appreciated.
I have tried to attach the STL file but the error  is shown....
Correct the highlighted errors and try again.
  • The attachment's flexi_75_wallpipe_flat_funnel.stl content type (application/vnd.ms-pkistl) does not match its file extension and has been removed.
Daniel
zcqsdmd
Managed to attach what I am trying to recreate.
laughingcreek
I would probably do it something like the attached
jeff_strater
Way too many points.  You would be much better off using Create Mesh Section and Fit Curve to Mesh Section to reverse-engineer the lower shape (never use the "faceted" Mesh to BRep conversion, IMO), and then create a simpler loft...
Jeff Strater
Engineering Director
zcqsdmd
Thanks for both of your help. I have used the mesh section succesfully so its only referencing a circle cross sectio n of the mesh rather than the dozens of points. This has cleared up the loft somewhat. Though now I can only shell to a distance of 0.5mm which is somewhat progress but not enough.  How do I simoplify the geometry so a 2mm shell can be achieved?
Thanks for your walkthrough Laughing creek. Exactly how did you sketch the guide rails so that are at an angle to the sketch plane (face on)? Hope this makes sense.
I have attached the latest attempt as V4.
laughingcreek
@zcqsdmd wrote:
...Exactly how did you sketch the guide rails so that are at an angle to the sketch plane (face on)? Hope this makes sense. ...
I checked the 3d sketch in the sketch palette and drew lines between points that already existed .
to get the loft to work well enough to thicken to 2 mm using your existing sketch geometry I had to resort to surface modeling.  see attached model.  the way yo have it drawn, this location here has reallt tight curvature at an awkward angle relative to the circle your lofting from-
one of the likely reasons this is a difficult loft.  in addition to giving the loft difficulty, operations like shell/thicken will have more difficulty with tight curves than it will with a sharp corner.  possibly a reason the ordinal designer opted for a transition with a larger radius curvature at this point.
zcqsdmd
Great thanks for your help I have managed to recreate it myself successfully!
