possible bug with the curvature comb ignoring scale or getting fragmented
cekuhnen
Mentor Mentor
cekuhnen
so I noticed that the surface edge comb is better than the curve comb
but as it turned out the sketch comb only worsk with small scale values
too much scale and the left comb will not scale anymore breaking the flow
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
jakefowler
Hi Claas,
I was able to reproduce the effect here. I believe the comb scale is being limited based on the curvature of the curve. But it's allowing this limit to apply to different curves within the same selection group, giving the odd effect you are seeing. You're right that this doesn't seem to be the correct behaviour - I'll follow up on what's going on here and whether a fix is possible.
If you ensure that the scale values are the same for each curve, you should get an accurate reading at the connections ('Smooth' constraint = red lines touching = G2).
Thanks for reporting this one!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
cekuhnen
That's what I thought because the surface edge comb was perfect this the curves are too just the comb is broken apart scale wise
Claas Kuhnen
