better way to make blend curves than fixing target curves?
cekuhnen
Mentor Mentor
cekuhnen
I often do not want when making a blend curve that the primary cuvres / target will get changed because their
tangent handles get activated
here is a quick vid
https://drive.google.com/open?id=0Byzv_NlyKp_2NkZzVG1zcUFXOFk&authuser=0
here is a vid showing some of the struggles which is why I started to fix lines
https://drive.google.com/open?id=0Byzv_NlyKp_2d3IzU2I0aEtXa2c&authuser=0
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
jiang_peng
I noticed in your video, you didn't set the "Comb Scale" of curvature comb. If you want to check if 2 curves are G2 continuity, please select the curvature combs and set them to same "Comb Scale" value
thanks
cekuhnen
the comb scale function is broken and when scaling too much will scale the combs of the elements differently giving you the impression continuity is broken.
when doing the surface edge comb all works as expected!
Claas Kuhnen
