possible bug: loft rail surface failure
cekuhnen
Mentor Mentor
cekuhnen
https://drive.google.com/file/d/0Byzv_NlyKp_2TVp3Nm9aZ3AxeTA/view?usp=sharing
Loft fails to make a suface here lol
Sweep is even more funny
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
So it looks like that one edge is messed up for some reason, since could make that loft on the other side.  So one way I fixed that is to Split body a little bit back from the edge (using offset plane as splitting tool), then re-extrude the edge back to where it was to create a clean uncorrupted edge (again kudos to Michal).  Here is the end result:
With this good edge no problem with sweep either, after first making a curve in a new sketch using intersect (the surface will just "kiss touch" the sketch plane, so Intersect works (always/usually good to use Intersect, which for example in this case verifies touching surface with sketch plane).
Also as an interesting sidenote, copying the body, then creating a Create Base Feature, then pasting the body, allows bugfree operation.  However then it's a DM feature, so not parametrically editable.  I really like the first fix, and is widely applicable with similar situations.
Jesse
cekuhnen
yeah something goes wrong - i suspect the split command creates edges not usable not sure but then the loft preview also should not work
experience that somewhere else before and it was a bug in the code that generated the edges
Claas Kuhnen
