Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Point or measure reference
3 REPLIES 3
503 Views, 3 Replies
Hi Guy´s
Newbie to fusion, and are wondering how to set the measurement reference from surface or fixed point?
Example: rectangle box with 2mm rounded curved inner corners, trying to place 4 cylinders 4mm in diameter inside on the floor of the box with preceision and i have no idea on how to set a reference point from a fixed point that i can use for placing the objects.
Can you possibly switch viewpoint to a flat surface without 3D vision and set a fixed measure point or how to do this in a proper way??
Thankful for any hints
BR
/ Andy
3 REPLIES 3
TheCADWhisperer
@Anonymous wrote:
...how to do this in a proper way??
Sketch circle with dimensions.
File>Export and then Attach your *.f3d file here for demo.
in reply to: TheCADWhisperer
Box!, trying to place inner cylinders with any accuracy
BR
/A
Hi CADWhisperer
Did i make a misstake by clicking solved?, uploaded the file
BR
/ Andy
Technology Administrators
