Hello everyone. I am new to fusion 360. I designed a mount for a small DC motor and I'm trying to 3D print it on my campus. I was told he could not print out the T shaped object but the other one was fine. What could be causing the issue? Could it be related to the two objects colliding?
I had one cylinder object slightly protruding into the other, then combined the objects. One object is just a cylinder shape, while the other was an sketch I obtruded in order to get the d-shaft in diameter shape.
How could I make the back end of the d-shaft to sit more flush against the other cylinder object?
I have attached the project, the render STL file and an image. Please take a look. I appreciate any help 🙂
