- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having an issue with circular pockets not cutting to the correct diameter.
I'm making tasting flight boards out of timber with 5 recessed 62.5mm diameter pockets at 2.5mm deep.
All the other cuts seem to come out accurate: slot, profile cut, but the circular pockets are coming out with a diameter of about 58mm instead of 62.5mm.
I'm using a 3.17mm flat endmill, and that's selected as the tool.
When I go into the sketch or inspect, and double check the measurements, the circular path has the correct 62.5mm diameter.
Anyone know what I'm doing wrong?
Also, I've noticed in the tool settings the "tool diameter offset" is set to "1"
What does that mean?
Screenshots below showing settings, paths etc, and the f3d file is attached
