Plane Form to Solid
Plane Form to Solid
ronan.tolla
Plane Form to Solid
ronan.tolla
I am trying to make a simple landscape to 3D print, however, I cannot seem to convert the plane I designed into a solid body. The formed plane should be the top surface of the body.
davebYYPCU
If that surface is totally watertight / manifold, then make a boundary fill under it.
make a floor and four walls to create a cavity, and then fill the cavity.
Might help.....
TheCADWhisperer
mango.freund
Hello - your work is made of shapes?
draw your circumferential lines with "old" downwards. this creates additional areas. the edges bring "sharp". then close the form below --- so it becomes solid and printable. if necessary cut your solid shape for printing. best wishes - merry christmas - mango
TrippyLighting
How did you create this model?
Does this originate in Fusion 360?
mango.freund
hello, I'm sorry, but there is no history. you have to pull all surfaces down and connect / weld to a last surface and keep sharp corners. then convert. merry christmas - mango
lorak83955
Community Visitor
Community Visitor
Hey, have you finally found what you were looking for.
 Mini Militia App Lock
