pipe array on curves
Hi
i am new to fusion 360
i want to draw a array of pipe and the bottom part need to be line up with curves like a wave.
i know the quickiest way is to draw another ellipse and cut the pipes but i need the pipe's bottom part are flat
currently i cut and move every pipe manually to create the wave curve that i want
please let me know if there is any way faster, thank you
*the last one is roughly the shape that i want but just full of pipes
擷取_2021_03_14_17_31_41_780.jpg擷取_2021_03_14_17_32_08_855.jpg擷取_2021_03_14_18_29_21_279.png
TheCADWhisperer
g-andresen
Project an ellipse (Project nto surface) onto a curved surface and use the projection for the pipe.
Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
Hi
here is the file, thank you
