Physical Materials - Concrete is missing
Hi there,
Despite my best efforts I can't find Concrete in the Physical Materials panel.
I mean - concrete seems like one of the basic materials that should be there?
How can this be fixed?
Concrete material is available only for rendering purposes in the appearance library of Fusion 360, not in the physical materials library because concrete is a composite material.
That being said, if you want to run an FEA simulation, you have to create a custom material that reflects the physical characteristics of your own mix (sand+gravel+water+portland+steel bars).
_Artur
And how to do it?
ckVCFWD
cool no answer. would love to find sand in the physical materials
CGBenner
@ckVCFWD
Hi, does THIS address what you need to do?
Chris Benner
TheCADWhisperer
@ckVCFWD
But there was an answer.  "Concrete" is meaningless without specifications.  You can create your material to your needed specifications.
Now about the topic "Sand".
What are your specifications for your sand?
