Perpendicular-to-tangent constraint?
JetForMe
JetForMe
Is there an easy way to constrain a line to be perpendicular to a curve at a point? I found a cumbersome way, with two lines, two points, two coincident constraints, and a perpendicular constraint, but that's very cluttered. I need to make a number of such lines, and don't know of a simpler way.
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
TheCADWhisperer
@JetForMe
There might be.
(If your actual file is proprietary - simply make up a dummy file that exhibits the same behavior.)
jhackney1972
Take a look at the video.  You will end up with multiple sketches but the method is easy.
(view in My Videos)
John Hackney, Retired
davebYYPCU
... a line to be perpendicular to a curve at a point?
Sure, draw a line from curve to it's centre point. (Radius line)
There are a few workarounds for Splines, but more context is needed for which one to use.
Might help.
TrippyLighting
Arcs show with a center point, and you can make a line perpendicular to an arc by using the coincident constraint between the line and the center point of the arc.
It's perhaps not as intuitive as a perpendicularity constraint, but it works the same effect.
Unfortunately, tangency, or perpendicularity to a spline curve, still requires workarounds.
MichaelT_123
Hi Mr JetForMe,
The theme "Tangency and Perpendicularity to Spline at Point" ... is popular on this Forum, like 'Dark Side of the Moon' by Pink Floyd. It is timeless.
This is the excerpt from:
https://forums.autodesk.com/t5/fusion-design-validate-document/tangency-and-perpendicularity-to-spli...
There are some more or less viable approaches to the conundrum posted already.
Please find another one below. I am not sure whether it has worked in previous Fusion sketch machinery, but it seems quite a natural, friendly solution now, but ONLY for 2D spline/sketch. For the 3D scenario, “a planeOnPath” is a viable solution.
What to do:
  • Draw a spline
  • For the existing one, insert a fit point where you want your line segment to be perpendicular
  • In the sketch trigger spline’s tangential handlers
  • Apply a perpendicular constraint to the line and the handler at the fit point of interest
  • That’s ALL
How to test:
  • Drag the fit point
  • Drag and end of  a tangential handler (changes its angle in 2D)
  • Drag the line itself (by position and/or angle)
  • That’s ALL … I can think of!
The simple test file is attached.
Have  Tangential_or/and_Prependicular 2026
MichaelT
MichaelT
