- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm aware that performance of sketch with a large repeat pattern is painfully slow. However, it's challenging working with something that is slower than molasses on a cold winter's morning. So I'm trying to find out if it's my configuration, or this level of performance is expected.
I'm attempting to create a vacuum table for my 4'x8'CNC router. It comprises 48 x 96 x 3/4" sheet with a matrix of grooves to take different configurations of cord gasket. The grooves also creates passages to distribute the vacuum. My approach is to take a 1.75in square and create a regular pattern, which in my case, will be 23 repeats x 48 repeats. The resulting 1058 matrix just bogs down my machine. Once I get the sketch I would select the gap and extrude it cut the grooves in the sheet. Hopefully, my description is enough for anyone to get the idea. (i.e. draw a 46 x 96 in rectangle and fill it with 1.75"squares, leaving .25"gap between them)
If I do this in sketch, it takes well over an hour for F360 to come back to life. During that time Windows resource monitor reports F360 as not responding. CPU is running around 12.5% with 80+ threads. F360 displays "computing sketch 94%). If I do this in 3D (using pattern features), it's a little faster, but still nothing to shout about.
My machine is no slouch -
Windows 10
Processor: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s)
32G of installed RAM
SSD hard drive
NVIDIA GeForce GTX 1070 with 8G memory
I can't think what I am attempting to do is anything particularly unusual. If anyone has any ideas how I can resolve this, I'd really appreciate the help.
Many thanks in advance
Peter
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
