PERFORM THE ANIMATION OF THE DEVELOPMENT AND COMPLETION OF A PACKAGING
gla1972
Message 1 of 9
gla1972
Hello everybody!
I am new to Fusion and I would be interested in designing a Packaging and obtaining at the end of a project, an Animation of its development, that is, showing how it is bending and "joining" until the final result is reached. All this with and without rendering and scenery ...
As an example, it would be something like a box of any product, a TV for example, which starts as a flat cardboard, then comes the die-cutting and finally, the final assembly ...
I hope you understand what I am looking to do.
Thanks in advance.
Greetings!
Replies (8)
Message 2 of 9
ritste20
Initially, I would say to design the cardboard packaging as a sheet metal component to utilize the flange and flat pattern features if you are designing this for production. If you are doing this with the end goal of animating it and producing a movie clip showing the folding motions you will need to design the "box" as a sum of the component segments so that you can manipulate them individually in the animation environment.
Unfortunately, I don't believe Fusion is capable of animating the sheet metal fold/unfold functions yet so that is not the way to go depending on the intended outcome.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 3 of 9
rushabhthakkar_910
Yes, I too agree with @ritste20, currently this is not possible... And found a similar topic.. https://forums.autodesk.com/t5/fusion-360-design-validate/animating-bends-and-complex-geometry/td-p/... ...
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 4 of 9
mango.freund
hello @gla1972
that would be an excellent question for the group of experts.
please register  you.
"Invite to "Ask the Fusion 360 Experts."
register and it will be clear how fusion creates its animations.
brad tillis - lars christensen and others in the team may have the answer you are looking for.
greetings mango
Message 5 of 9
gla1972
Hi, thanks for your answer, but I don't know how to do that Invite to "Ask the Fusion 360 Experts."
Thanks!
Message 6 of 9
rushabhthakkar_910
I guess maybe @lars_christensen can guide us on when the next session will take place..
Thanks and Regards,
Rushabh Thakkar.
Message 7 of 9
ritste20
https://forums.autodesk.com/t5/fusion-360-design-validate/invite-to-quot-ask-the-fusion-360-experts-...
Registration link is in the pinned discussion.
Steve Ritter
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 8 of 9
rushabhthakkar_910
Oh... I thought the Link was of the previous session... Thanks for the Link.. https://autodesk.zoom.us/meeting/register/tJ0qdOyuqzIoHdFAjw3cBJNjRvIqQlvufAcN
And next Session is on June 9..
Thanks and Regards,
Rushabh Thakkar.
Message 9 of 9
gla1972
I add an approximate image of the packaging that should be animated, from an "unfold" to a "fold" state, that is, the whole process from when it is a flat cardboard, then it is die-cut, and finally it is folded and assembled ..
Obviously the picture is in the rough, being an approximation of the idea...
Thanks!
