Would anyone have an idea on how to create this?
MattL48WM
MattL48WM
sspring.PNG Any suggestions help.. been stuck on this for hours.
ritste20
What are you trying to do? It appears that you have something there so what do need to create?
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
g-andresen
please show what your goal is.
and
share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Prashant_Jha
It's very easy. Just you have to make concentric circles and then apply filleted corners at the cuts to obtain a smooth curved sketch.
Have a look at mine model. Hope it will give you a clarity.
rushabhthakkar_910
See this Screencast Video... 👉https://autode.sk/34JpRUz
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
TheCADWhisperer
@MattL48WM Whenever you make an attempt at geometry and run into difficulty - you should Attach your attempt here.
(See my attempt Attached below.)
