Perform Emboss, Create New Body
1 REPLY 1
scodavis
158 Views, 1 Reply
I have been trying for a while to create an emboss with a new body.  I know that the emboss function doesn't have a "Create New Body" checkbox, so I'm trying to find an alternate workflow that works.  I've done a lot of searching, even finding another similar post, but I wasn't able to recreate the result.
I have a cup body that is approximately 3mm in depth.  I've already created my text inlay and performed an emboss of 2mm as I don't want the embossed text visible on the inside.
What I want to do now is re-fill in the embossed area, but have it be new bodies so that I can use two-color 3d printing to have an inlay.
I've attached a photo of where the project is right now, and I've also attached the Fusion file.
Thank you in advance for your help!
1 REPLY 1
evanp4509U4JZ
in reply to: scodavis
Roll timeline back to before emboss. Offset outer cup surface in surface mode. Turn off surface. Roll timeline foreward passed emboss. Return to solid workspace. Turn on surface and perform boundary fill.
