Patterns: progressive spacing?
Trying to create a pattern where the spacing is progressive. Meaning the pattern spacing gets progressively larger/smaller. Is there a way to do this? I was also wondering if it is possible to increase the dimensions or size/scale of a feature that is in a pattern?
TMC.Engineering
No, at least I am not aware of a way.
For something a simple as pictured. you could make a sketch that references a couple parameters and get the same result.
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
