parsing geometry with no selectable features
fishtruk
Message 1 of 13
fishtruk
Here's a simple shape. A disk with a rounded periphery. I don't know how to measure the overall diameter. I can't snap on the OD. I tried project also but project seems to only project the meeting of features - those black lines on the 3D objects.
Replies (12)
Message 2 of 13
Beyondforce
Have you tried the Measurement tool ("I" key)?
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 13
fishtruk
Yes, measure is the first thing I try. Also used the shift key to get the snap points, but there aren't any.
Message 4 of 13
Beyondforce
Could please attach the file?
Ben Korez
| YouTube
Message 5 of 13
fishtruk
here you go.
Message 6 of 13
HughesTooling
If you have a plane that is on the centre line of the part you can use Project Intersect and select the body. If you need to create a plane you'll need to use Axis through cylinder and select the hole then plane at angle and select the axis.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 13
When using the measure tool you can click and hold left mouse button, then select edge.
Message 8 of 13
HughesTooling
Here's a screencast demonstrating how to create a plane through the centre line of the part. File's attached.
Mark
Mark Hughes
Message 9 of 13
fishtruk
John, I think you're selecting the bottom surface. I'm trying to get the OD of the toroid shaped fillet around the disks.
Message 10 of 13
fishtruk
Thanks Mark.  Intersect eh?
Message 11 of 13
"John, I think you're selecting the bottom surface. I'm trying to get the OD of the toroid shaped fillet around the disks."
Yeah, I see that now. Sorry about that. Guess I need to get my eyes checked.
Message 12 of 13
fishtruk
Your eyes and my finger. It's worn out from all the hopeful clicking.
Message 13 of 13
HughesTooling
This is one of those situations where Fusion's pretty display is not helpful, most CAD systems would leave a seam where the revolve starts\ends but Fusion hides it.
Here's an example from Rhino.
Mark
Mark Hughes
