Pattern suppression problems
tergu
Message 1 of 23
tergu
I am having some issues when I try to suppress occurrences in my pattern:
1. the arrows to adjust the spacing hide 2 of the suppression checkboxes. I could get them unchecked in the end but it took me some time to find the exact right spot on where to click. See the screenshot below.
2. When I select the pattern in the timeline later to modify it all checkboxes are checked again. I am not quite sure if this has always been this way since I use patterns quite often, but maybe I never modified a suppressed pattern.
3. Is there an out of the box way of creating a staggered pattern, apart from patterning 2 already staggered features?
Best regards,
Christian.
suppress checkbox hiddensuppress checkbox hidden
Replies (22)
Message 21 of 23
laughingcreek
@tergu wrote:
..It seems like if I use "spacing" to create a pattern it will not retain the suppression properties. If I use "extent" it will, even if I change it to spacing afterwards and modify the parameters...
I can confirm that the behavior you describe here happens to me also.  It seems like the have only partially fixed this problem.
Message 22 of 23
TrippyLighting
Darned, I had missed that part. Yes, I can confirm that as well!
@jeff_strater or @karina.harper can one of you you check this out ?
Message 23 of 23
karina.harper
Autodesk Support
Autodesk Support
@tergu
Thanks for the tag @TrippyLighting  - I was able to reproduce this.
The 'can't check box under the arrow' issue has been logged, I'll add your note to the ticket. (FUS-33994).
The Pattern does not remember suppressed objects when using 'spacing' type is a new issue. I just logged this as FUS-55245. Thanks for reporting!
Cheers,
Karina
