Need advice on bent sheet metal design
Hey all, I'm still very much a beginner with CAD and Fusion and I'm not sure of the fundamental approach to creating a design from a single piece of sheet metal with multiple bends. My understanding is I can't just sketch it out as a single, flattened component and then add the bend lines/angles (though, oddly, I know Fusion can "flatten" your design once you've finished it - too bad it can't do the same in reverse). So, how would I sketch and model the object?
For example, assume I want to create an M shape from a 1" wide, 12" long strip of sheet metal that incorporates 3 bend points and four 3" legs. I can't simply create a single extrusion that's 1" wide and 12" long and add bend lines and angles at 3", 6" and 9" (wouldn't that be great though?). So I start by sketching the first leg of the M (3" long, 1" wide). Now what do I do for the next leg of the M? Do I need to create a new 1" wide, 3" long sketch on the appropriate plane and extrude that object? Or do I simply create a 3" long flange at an angle starting from the end of the previously-extruded leg? And do the same for the remaining two legs?
I hope my question makes sense. Just trying to understand the logical approach for doing this type of design work. Thanks!
