Pattern/revolve around an elliptical, tapred surface
lidberg.david
Message 1 of 13
lidberg.david
How is it possible to continnue this cut-out as a pattern around this shape? I ve tried a few things but everything ends up a big mess. Revolve applies it in a circle which it obviosuly isnt supposed to do. Sweep using one of the upper elliptical edges as a path does something else equally weird. And so on ...
Anyone please assist if possible.
EDIT// Link to f3d project file: https://ufile.io/gtd0o6o1
Replies (12)
Message 2 of 13
mango.freund
please give your work as a f3d file to us. thanks -- mango
Message 3 of 13
davebYYPCU
No file for your dimensions but can be done, you didn't say how many holes.
Might help....
Message 4 of 13
davebYYPCU
Like this one?
Message 5 of 13
KristianLaholm
Is it something like this you want?
* Revolved a slot creating a "tool body"
* Pattern on Path using tool body and a path created on a midplane ellipse body (path must be in center of body)
* Split face using tool bodies, removed tool bodies.
* Press/pull on split faces creating cut outs.
Message 6 of 13
lidberg.david
That is perfect! How did the inside surfaces in the cutouts end up to be 90 degrees to the curved surface if you used a tool shape at the center of the model? They ought to have been perpendicular to the base plane then no?
Anyway, tht is exactly what I was after. Thank you, and thank you to everyone else suggesteing solutions. Very appreciated!
Message 7 of 13
KristianLaholm
The tool shapes was only used to split outside face of the body, press/pull created the cut outs.
Press/pull will follow the "normal" of the face/surface, that gives the 90 deg cut angle to the curved surface.
Message 8 of 13
lidberg.david
Hm, a litle nitpicking / curious observation ...
The height of the tool body is constant along the path while the height of the face varies between a minimum at perihelion and a maximum at aphelion. Would it be possible to sweep a pattern that maintains a proportional height to the upper and lower edges of the face along the path?
Message 9 of 13
g-andresen
Very nice solution!
günther
Message 10 of 13
davebYYPCU
My version does that, where the body protrudes has proportionate geometry,
sounding like you want set Tangent distance from the body edge, on the external face?
That would require a different strategy,
Is it possible to announce the slot count?
Message 11 of 13
KristianLaholm
If you want a pattern to adjust you need to pattern a Feature and use Compute option Adjust.
In this case i make the Extrude of tool body to object and then the pattern adjust length of bodies along the path.
There are problems in the workflow, I only did it to show the possibility.
Message 12 of 13
lidberg.david
Nice! Very apprecited you taking the time with this. If I may, I ll claim some more of your time on a further iteration facet of this design.
Examining the surfaces inside the cut-outs, they _are_ done perpendicular to the face they are cut out of. However, the faces inside the cut-outs are not flat surfaces but rather minor arcs of the circumference of the tool body. How would you produce these cut-outs while at the same time produce completely flat surfaces inside the cut-outs?
Message 13 of 13
KristianLaholm
The faces of the cut outs are normal to the outside surface using Press/Pull, they are not from the shape of the tool body.
If you by "flat faces" want them all to follow the same vector? I don't know of a workflow that easy can create that.
There can be some possibilities using manufacture but I think it will be time consuming.
